Hi
We have a adhoc network, for example its ssid is SSID1, it works on g-band.
I want to have this adhoc network functioning. while i want other adhoc networks to be detected and protected from it.
so, i have the options "Detect Adhoc Networks" and "Protect from Adhoc Networks" turned on in the "IDS Unauthorized Device profile"
My needed adhoc network SSID1 is having issues to work on the vicinity of the APs in the infrastructure. however the same adhoc network works fine away from the infrastructure APs.
Any suggestions, on how i could have my needed adhoc network working. My infrastructure controller should not do any IDS activity on the needed adhoc network.
