Occasional Contributor I
limit client number per ap
I have AP103 with two ssid on each AP and I want to limit the number of client to 60 per AP.
I've set the "Max Associations" in the ssid profile but this parameter is per ssid and per radio. So I' can have at max 240 client per AP (2 ssid x 2 radio x 60 ).
Is there another parameter to set to limit association per AP ?
Re: limit client number per ap
The answer is no:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/Can-I-limit-the-number-of-clients-per-SSID/ta-p/182422
If you have clientmatch enabled (it is enabled in ArubaOS 6.3 and above by default), it will attempt to load-balance clients, but you will probably end up with more than 60 on an access point if you do not have enough access points to deal with your density..
Colin Joseph
Aruba Customer Engineering
