low case "i" mean for ap's flags
hi ,
what is mean of low case "i" for ap's flag as diagram shows:
Aruba
Re: low case "i" mean for ap's flags
I am not sure what the "i" flag specifically means, but I see it is a 275 AP.    Are the radios disabled when you believe they should not be?
Run the following to see if you are having the issue; check to see if the Operational State has been "Overriden by LLDP"
show ap debug system-status ap-name DG-LeemanPBC-Out-275 | include POE
AMFX | ACCX | ACDX | ACMX
