lower data rates
Is it true that  we should not  disable  lower data rates  to save airtime like 1 ,6 Mbps.
If its true what reason ?
Re: lower data rates
Take a look at the VHD VRD which discusses data rates in great detail.
There is also an RF optimization wizard on ASE.
Tim Cappalli | Aruba Security
kpaly wrote:
Can you please show where that is written?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I think  its in one of the videos( cwna) jeromy I belive
You might want to ask Jeromy if that is where you see it..
Maybe Jeromy is pointing something else . My understanding might be wrong :)
Here is the statment
802.11b and 802.11a set default data rates to make sure that all stations would understand all modulation in the (new in those days ) protocols
Frequent Contributor I
There is no single answer, it is dependant on many variables. Client type and enviroment details are probably the biggest determining factors.
Here's some thoughtful writing on the topic- http://www.sniffwifi.com/2016/01/why-you-shouldnt-disable-low-wi-fi.html (Take with grain of salt before you apply generic advice to your specific environment.)
