mac address authentication problems
I have an Aruba 650 controller with version 6.2.1.1.
I need to set up two wireless networks, one with mac address authentication only and the other with mac address authentication and captive portal.
I'm not getting the mac address is authenticated. Can you help me?
Re: mac address authentication problems
What have you configured already and what is not working?  We do not have enough information to help you.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I have both configured SSID, and another one in Open Open with Captive Portal.
Then I followed the manual transmission attached.
Best regards,
ccarrico
turn on user debugging:
config t
logging level debug user
Disable the client's wireless card then delete the client from the user table:
aaa user delete mac <mac address of user>
 Enable the user's wireless card to attach it to the network, then display the logs for that user to determine what is happening:'
show log user 50
I did the procedure you asked me, send attached result (log)
Best regards,
ccarrico
it says "
Jun 5 16:25:09 :522190:  <DBUG> |authmgr|  MAC=6c:e9:07:dd:c3:3a IP=0.0.0.0: MAC auth fail: entry-type=L2, bssid=6c:f3:7f:49:84:30.
Is that the device?  What format are you using for the mac addresses?  Is that format in the mac authentication profile?  Did you enter the mac address in the internal database with username and password in the same format?
Right now my problem is that the user exists or not created, it always has access to the internet
Best regards,
ccarrico
A user will ALWAYS get the initial role of the AAA profile that he is attached to.  If you make this a "deny all" profile that has no acls, users that do NOT pass mac authentication will end up in this role.  Users that do pass, will be assigned the mac authentication user role, OR the role assigned to their mac address in the local user database.
It will be quite painful to expose all of the options available to you on the forum here, so I suggest you open a TAC case if you want quick, concise support.
