maximum number of users 400
 for by example the AP-334/335
dos the limit 255 is hard or recommanded ?
if  there is two over users over the 255 what happen ?
my customer want an AP indoor and outdoor that support the 400 users (every users with 2 MBPS): the solutions ?
Best regards
Zammit Ikbel
Re: maximum number of users 400
255 is the hardware limit, but it is not practical to plan for 255 users.
You cannot serve 400 users on an access point.  You would have to deploy multiple access points to achieve your goal of 2 megabits per second.
What devices and what application will these users need to use?
Colin Joseph
Aruba Customer Engineering
