Valued Contributor I
memory upgrade for A800 Controller
I've just tried to upgrade the firmware on my A800 controller to the latest release (A800_5.0.4.13_40042) and it fails because of "insufficient memory" and tells me that I need a min of 45Meg. I've cleared out any log files and backup configs but it still complaines.
What memeory is it complaining about .. flash storage or RAM?
If RAM can you upgrade these beasts?
Rgds
Alex
Aruba
Re: memory upgrade for A800 Controller
Does the failure occur when you are FTP'ing the firmware file to the controller ?
Or is the failure after the file transfer?
JF
Got file on local hard disk and am uploading file directly instead of tftp  or ftp via browser.
Rgds
a
Aruba
Thanks 'a'.
Let us know how you make out.
JF
