Frequent Contributor II
mesh portal negotiated power
hello Airheads,
anyone know if it's possible to power a mesh portal (model number 277) from a 802.11at power injector?
We have tried but the logs say no radios coming up because lldp couldn't negotiate power capability.
i am thinking maybe disabling lldp for this AP. ANY IDEAS? Cheers
pete
Re: mesh portal negotiated power
What model power injector are you using?
hi Colin,
microsemi acdc60g 1 port 4 pairs 60watt power injector.
cheers
pete
hi Colin,
we are trying to work out if the device is 802.11at compatible. The literature is a bit ambiguous.
we are sourcing another power injector.
cheers
pete
The datasheet here;  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/17321/Default.aspx says that it is 802.3at compatible.  You also might want to check your cabling to be sure...
That injector is not AF/AT compliant. See attached datasheet.
Jerrod Howard
