Frequent Contributor II
mesh portal power
I have a mesh network with 2 portals. Recently all points have been connecting to the #1 portal. I bumped the power on the #2 portal to max as a test and all the APs moved to #2. Am I correct to assume that by powering the #2 portal down slowly, eventually I will get an even distribution of points to portals?
Super Contributor I
Re: mesh portal power
Have you changed the algorithm in the mesh radio profile? Typically the distributed tree option is supposed to take into account mesh portal load.
ACDX #419 | ACMP |
I found that setting and it is set to the distributed model.
code: 6.3.1.7
Nevermind, saw you checked that already
Mesh Radio profile
Config > Mesh > Mesh Radio > <profile>
Also check your reselection-mode. What is it set to?
Both portals are on the same AP group correct? Or are the two portals in different groups?
Jerrod Howard
