Frequent Contributor II
mesh redundant portal
I've got a point to multipoint configuration at a customer site and whent he main mesh portal goes down, another portal is supposed to take over.
This is not happening. Once the main portal goes down, the entire mesh goes down and the redundant portal stays up. Where can I check this configuration? The system has worked in the past and just stopped working when upgrading from an old controller to a 7200.
Re: mesh redundant portal
Can you please share how you have this configured ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I've included everything i think is relevant...
ap mesh-recovery-profile cluster RecoveryCxXNI8gKXgR3fsvx wpa-hexkey "long encrypted key"
crypto isakmp policy 20
  encryption aes256
ap wired-ap-profile "CU-WAP-1"
   wired-ap-enable
   trusted
   switchport access vlan 20
   switchport trunk native vlan 7
ap mesh-ht-ssid-profile "default"
ap mesh-cluster-profile "default"
ap mesh-cluster-profile "Cust_mesh_cluster_1"
   cluster "Cust_mesh_cluster_1"
   opmode wpa2-psk-aes
   wpa-passphrase 68147f72a233e02af9490f6fcad0c403fcce124d5544a31d
ap mesh-cluster-profile "Cust_mesh_cluster_2"
   cluster "Cust_mesh_cluster_2"
   opmode wpa2-psk-aes
   wpa-passphrase 42bd0d6f0e8c10b381d744352ee2b7627130fdf0f95626dc
ap mesh-radio-profile "Cust_mesh_radio_1"
ap mesh-radio-profile "Cust_mesh_radio_2"
ap wired-port-profile "CU-WAP-1"
rf arm-profile "Cust_mesh_arm_profile"
   min-tx-power 127
rf dot11a-radio-profile "Cust-max-arm-power-rp"
   channel 161
ap-group "AP_Mesh_1_MeSh"
   virtual-ap "Cust_employee_vap"
   virtual-ap "Cust_device_vap"
   dot11g-radio-profile "Cust_mesh_g_radio_profile"
   ids-profile "Cust_ids_low"
   mesh-cluster-profile "Cust_mesh_cluster_1" priority 1
   mesh-cluster-profile "Cust_mesh_cluster_2" priority 2
ap-group "AP_Mesh_2_MeSh"
   enet0-port-profile "CU-WAP-1"
   enet1-port-profile "CU-WAP-1"
   mesh-cluster-profile "Cust_mesh_cluster_2" priority 1
   mesh-cluster-profile "Cust_mesh_cluster_1" priority 2
bump?
Do all portals need to be on the same channel?
They need to be on same mesh link channel on .11a
Thank you
Victor Fabian
