meshing between two buildings
  • 1.  meshing between two buildings
    Posted Feb 26, 2014 03:03 PM
    Good afternoon,
    We are building out one of our properties with two large buildings.  We are looking to use an Aruba 3400 controller in building 1. There are three 48-port POE switches in building1 & three in building 2.  the buildings are 900 feet apart with a line of site.
    Im not too knowledgable with meshing the network so all six switches are off the one contoller. What would be the recommended antenna configuration for this mesh assuming Im using AP175s?
    Thanks!
    #3400
  • 2.  RE: meshing between two buildings
    Posted Feb 26, 2014 07:37 PM
    If it just for a point to point communication between both building
    Like if it was a cable between both building you could use mst200
    Here is more info about it
    http://www.arubanetworks.com/products/mesh-routers/mst200/
    https://www.youtube.com/watch?v=mAGL7IqDPhU
    Cheers
    Carlos
  • 3.  RE: meshing between two buildings
    Posted Feb 26, 2014 07:39 PM
    I just saw that you said that we should assume that you are using a AP 175P?
    Why is that? you already bough it? or you assuming thats the best option you got?
    Cheers
    Carlos
  • 4.  RE: meshing between two buildings
    Posted Mar 03, 2014 10:48 AM
    Carlos,
    No,  I didnt buy the 175s,  just more familier with it.  Please let me know what our other options are.
    Thanks!!
  • 5.  RE: meshing between two buildings
    Posted Mar 03, 2014 10:52 AM
    Hello
    I already said mst200 and put info on previews message
    Just take in mind this will just buld the link between 2 buildings... it wont serve clients... but its cheaper than the ap 175 + antenas.
    Cheers
    Carlos
  • 6.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:03 AM
    Carlos,
    We are looking at installing around six 48 port Cisco POE switches with many AP105s on both sides of this mesh.  Do you feel this router will have enough horsepower?
  • 7.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:06 AM
    oops clicked accidentally solution accepted...
    mmmm
    ill see how to remove it...
    Anywaywas... the link speed its 300Mbs
    If you need more speed i ll advise you that you can use AP 274
    Its the new outdoor solution of aruba
    Take a look of it
    http://www.arubanetworks.com/products/access-points/270-series/
    Cheers
    Carlos
  • 8.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:12 AM
    Now im mentioning this.. i got a webinar of this AP for partners... as its new... ill ask more about it and ill come back to you.. its on 30 mins though
    Ill ask them specifically for your enviroment
    You plan putting 48 APs 105 on the other building? and instead of using a fiber link you will use a on the air link meshing right?
    Just to put them the scenario to see what they tell me.
    But i bealive this would be the best.option if you are looking for a fast speed link in the air.
    Cheers
    Carlos
  • 9.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:18 AM
    We already purchased the plain 3200, not the 3200 MX.  I guess that leaves up with the mesh router or the Ap175, correct?
  • 10.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:23 AM
    Yes, I believe we bought the memory upgrade already.  However, we did not buy the 3200 MX
  • 11.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:29 AM
    IF you already bough the memory upgrade then its all cool you just need to upgrade your controller to the correct firmware, to support the AP 274/275.
    You have to take in mind the BW you will be using on the other building....
    Remenber that your uplink between both building will be just 300Mbps and if you dont bealive that uplink will be enough then you should be looking for the  274/275, for 1 Gbps of speed.   The only one that knows if the 300Mbps is enough its you as you are the one that knows the BW that you will be using in the other building....
    Cheers
    Carlos
  • 12.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:28 AM
    Carlos,
    I stand corrected.  My engineer just told me we did buy MX. With 1 Gig.  Sorry
  • 13.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:46 AM
    Carlos,
    If the MST200 has its own OS, how is this typically managed?  Currently, we manage or will be managing 150,  3200, & 3400 controllers from Corporate.  can this somehow present itself as two Site APs in Airwave?
    If we choose the 274/275, how is this powered and cabled?  A couple guys here heard it requires AC, and two cables running to it.
    Thanks.
  • 14.  RE: meshing between two buildings
    Posted Mar 03, 2014 12:07 PM
    I balive is managed by web
    The tihing is that i actually have not installed one myselft... but should be installing 4 of them soon... and can tell you more details about it...
     the 274/275 can be powered by POE
    You can see it by yourself on the notes
    For more information abut the MST200 maybe you can ask your reseller, maybe they already installed them and can give you more information...
  • 15.  RE: meshing between two buildings
    Posted Mar 03, 2014 12:11 PM
    One lsat thing about your last question as someone asked on the webinar if it can be powered by poe and ac at the same time...
    They replied that you can but it will take the POE  as preferred for the energy as its build taht way....
    Cheers
    Carlos
  • 16.  RE: meshing between two buildings
    Posted Mar 03, 2014 01:15 PM
    Calos,
    After talking with our engineers, they dont want the MST200.  They do want me to look at the AP270 series.  I downloaded the deployment manauel your directed me to.  Ill look this over.  Is there a youtube link such as the one you directed me to for the mst200?  Is the AP274/5 available today?
  • 17.  RE: meshing between two buildings
    Posted Mar 03, 2014 01:22 PM
    Sure
    Here is the link
    http://community.arubanetworks.com/t5/Technology-Blog/Outdoor-802-11ac-Wi-Fi-that-goes-fast-and-looks-good-while-doing/ba-p/138479
    In here you will find more information about it, also a video of the introduction of the AP of the wireless filed day 6!
    Hope this information helps your engineers!
    Cheers
    Carlos
  • 18.  RE: meshing between two buildings
    Posted Mar 03, 2014 03:24 PM
    In the AP275, In a litle confused by the definition of the Omin directional 3x3:3.  There are 6 built in omnis.  I assume three are for the 2.4 and three are 5 ghz.  are all 6 three pole, such as 2H and 1V?
  • 19.  RE: meshing between two buildings
    Posted Mar 03, 2014 03:33 PM
    Sorry, I don tthink i can asnwer so specific questions about the engineering of the AP...
    You can also ask them questions regarding this antena on the link i provided you.  Specialist of that product will asnwer you in there...
    Cheers
    Carlos
  • 20.  RE: meshing between two buildings
    Posted Mar 04, 2014 12:34 AM
    EJohnson provided the answer - http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Built-in-antennas-in-an-AP275/td-p/145069
    3 omnis antenna are 2.4 GHz (2 are V polarized and 1 is H polarized)
    3 omnis antenna are 5 GHz (2 are H polarized and 1 is V polarized)
  • 21.  RE: meshing between two buildings
    Carlos,
    What is the advantage of using the outdoor router over using the AP175?  Is it better throughput?  Can I continue using the 3200 controller?
    Thanks!
  • 22.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:16 AM
    Just to clarify,
    I only have a total of around 20 AP105s on both sides of the mesh.  Other ports (not many) will be for security cameras.
  • 23.  RE: meshing between two buildings
    Posted Mar 03, 2014 11:22 AM
    yes but you can buy a memory upgrade so its all good...
    If you buy the memory upgrade you will be able to upgrade in firmware your 3200 to 6.2.x 6.3.x and so on.
    For now without the memory upgarde you just can go to 6.1.x...
    I advice you to buy that memory upgrade as the development for 6.1.x alredy  died.... and the support will be until this year on may...
    http://www.arubanetworks.com/support-services/end-of-life-products/
    So try putting that memory upgrade in the budget!
    Cheers
    Carlos
  • 24.  RE: meshing between two buildings
    Well its cheaper as its specific for that scenario!
    MST200 does not need any controller... it has their own OS....
    Now the other option i just posted you will be needing the 3200MX
    Now take in mind 3200MX
    if you got a 3200 alone then you will need a mem upgrade package to upgrade it to the lastest firmware tnat is needed to support the ap 274/275
    If you dontwant to buy the mem upgrade then you can use the AP 274/275 in instant mode(but it still not out the instant mode)
    It will be out in a few months i bealive.(The instnat mode) The controller mode is already out
    Cheers
    Carlos
  • 25.  RE: meshing between two buildings
    Posted Mar 03, 2014 10:55 AM
    Got it;  Ill take a look now.  Thanks!
