mobility controller 650 does not support VPN with IAP
I'm trying to set up a vpn between IAP 105 and mobility controller 650, requesting TAC support me answers that the controller 650 does not support VPN with IAP, is this true?
MVP
Re: mobility controller 650 does not support VPN with IAP
[ Edited ]
i have done IAP VPN to a 620 controller with no issue... with a RAP 155 and a RAP 3
There should not be an issue with an instant 105
Fallow my tutorial
http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Tutorial-Building-a-VPN-from-a-IAP-Cluster-to-a-Wireless/td-p/122585
Cheers
Carlos
Alternetworks Corp
MVP
you can also fallow this tutorial
https://ase.arubanetworks.com/
Click get started and look for the IAP vpn to mobility controller and it willl tell you how to do it
Cheers
Carlos
Alternetworks Corp
MVP
According to the ArubaOS release-notes, IAP-VPN is mentioned as unsupported on the 600-series for AOS 6.3.1, 6.4.0 and 6.4.1.
The new 7005 controller does support IAP-VPN.
thanks hrobers
I read the release notes, and I found that the controller 650 does not support IAP VPN. I have to buy a controller 3200. :smileysad:
Contributor I
hi, I have a 650 controller and are terminating. It has limited functionality though. It does only support L3 with NAT from the IAP into the controller. It is not possible to access equipment behind the IAP from the controller side. The other way (from IAP to controller network) is working just fine.
