Frequent Contributor II
modulation used by client transmit power control and AP usage
We are doing testing for Multicast over wireless ( without DMO) need help understanding below points
1. Can we check the current modulation type the client is using ? ( MCS index or something similar)
2.Usage details of AP / radio . Specifically from CLI.
3. Is automatic transmitt power control is available for both uplink and downlink?
Re: modulation used by client transmit power control and AP usage
1. Can we check the current modulation type the client is using ? ( MCS index or something similar) - A wireless packet capture is the most accurate means to reveal the MCS rate of every frame.  Anything on the controller will just be a snapshot in time MCS (statistics might only be updated every 60 seconds).
2.Usage details of AP / radio . Specifically from CLI. - show ap debug radio-stats ap-name <name of ap> radio 0 advanced should give you all the radio stats of the AP.
3. Is automatic transmitt power control is available for both uplink and downlink? - Please be more specific
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
