Occasional Contributor I
n type AP not broadcasting g-Ht
hi ,
As i had installed AP-121 but few of the APs are not broadcasting g-Ht band
as the o/p of 1 ap-121 >sh ap bss-table
bss                ess          s/p   ip            phy  type  ch/EIRP/max-EIRP  cur-cl  ap name                          in-t(s)  tot-t       mtu   acl-state  acl
00:1a:1e:35:85:83  Guests      pc-1  10.191.1.2    g    ap    11/20.5/20.5      1       Bharti Grnd Flr in front of 101  0        1h:58m:48s  1500  -          6
00:1a:1e:35:85:80  WIFI1       pc-1  10.191.1.2    g    ap    11/20.5/20.5      4       Bharti Grnd Flr in front of 101  0        1h:58m:49s  1500  -          1
00:1a:1e:35:85:81  WIFI2       pc-1  10.191.1.2    g    ap    11/20.5/20.5      0       Bharti Grnd Flr in front of 101  0        1h:58m:49s  1500  -          1
Re: n type AP not broadcasting g-Ht
Can you run show wlan ht-ssid-profile and post the results?
Tim Cappalli | Aruba Security
High-throughput SSID profile "Aruba_htssid_prof"
Parameter                            Value
High throughput enable (SSID)        Enabled
40 MHz channel usage                 Enabled
MPDU Aggregation                     Enabled
Max transmitted A-MPDU size          65535 bytes
Max received A-MPDU size             65535 bytes
Min MPDU start spacing               8 usec
Supported MCS set                    0-15
Short guard interval in 40 MHz mode  Enabled
Legacy stations                      Allowed
Allow weak encryption                Disabled
Check your 802.11g radio profile and make sure that "High throughput enable (radio)" is active.
List all profiles:          show rf dot11g-radio-profile
View profile:               show rf dot11g-radio-profile DOT11G-RADIO-PROFILE-B
802.11g radio profile "DOT11G-RADIO-PROFILE-B"
Parameter                                      Value
Radio enable                                   Enabled
Mode                                           ap-mode
High throughput enable (radio)                 Enabled
Channel                                        N/A
Transmit EIRP                                  15 dBm
Non-Wi-Fi Interference Immunity                2
Enable CSA                                     Disabled
CSA Count                                      4
Spectrum Monitoring                            Enabled
Spectrum Monitoring Profile                    default-g
Advertise 802.11d and 802.11h Capabilities     Disabled
Spectrum Load Balancing                        Disabled
Spectrum Load Balancing Mode                   channel
Spectrum Load Balancing Update Interval (sec)  30 seconds
Spectrum Load Balancing Threshold (%)          20 percent
Spectrum Load Balancing Domain                 N/A
Beacon Period                                  100 msec
Beacon Regulate                                Disabled
Advertized regulatory max EIRP                 0
ARM/WIDS Override                              OFF
Reduce Cell Size (Rx Sensitivity)              0 dB
Management Frame Throttle interval             1 sec
Management Frame Throttle Limit                20
Maximum Distance                               0 meters
RX Sensitivity Threshold                       0 dB
RX Sensitivity Tuning Based Channel Reuse      disable
Protection for 802.11b Clients                 Enabled
Adaptive Radio Management (ARM) Profile        ARM-G-PROFILE-B
High-throughput Radio Profile                  default-g
AM Scanning Profile                            default
802.11g radio profile "Bharti 101"
Parameter                                   Value
Mode                                        ap-mode
Channel                                     N/A
Transmit EIRP                               51 dBm
Spectrum load balancing                     Disabled
Spectrum Load Balancing domain              N/A
RX Sensitivity Threshold                    0 -dBm
Non 802.11 Interference Immunity            Level-2
Enable CSA                                  Disabled
CSA Count                                   4
ARM/WIDS Override                           Disabled
Adaptive Radio Management (ARM) Profile     default
the ht is enabled even though not broadcastin g-ht
What kind of encryption are you using?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
WPA 2 enterprice Authentication
AES encryption
with a security certificate
Vikas,
You should try recreating a parallel SSID with the WLAN/LAN Wizard from scratch to ensure that everything is configured properly.
