need ap 365 latest firmware
I try to download the latest firmware for Aruba AP 365 and IAP 207 (ver 6.5.3.2), but I couldn’t find the firmware in Aruba website. Kindly help me to get the link. If it not available kindly suggest the common firmware for both
Re: need ap 365 latest firmware
if you have an account on support.arubanetworks.com, you will be able to download it there.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
You should be able to get it by checking for updates on the instant Maintenance menu.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i checked the site and i can find only one ver for ap 365(ver 6.5.2.0 ).this version not supporting in uae.so thats why  i am checking for another vertion  for both this access point.
for the 207 you need the "VELA"version of firmware. which can be downloaded from the support site.
I noticed today not every release is available for the VELA (207) version.
browsing throug the version list, i found 6.5.4.0 (latest) to be available (please beware, airwave strugles whith this version :))
6.5.1.x seems to be the "first" VELA version
https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/26265/Default.aspx
