Frequent Contributor II
per-command authorisation for management users
I'm pretty sure I read that per-command authorisation for management users is not available, but the post was a little old (2014) so thought I'd check whether this is still the case?
Many thanks,
Re: per-command authorisation for management users
ArubaOS for controllers does not have TACACS command authorization.
Tim Cappalli | Aruba Security
Actually this is for Radius, but I assume the same would be true?
