phone on hospitality ap wired port
  • 1.  phone on hospitality ap wired port
    Posted Sep 12, 2016 01:02 PM
    I am testing a 205-H. At the moment when I connect a Cisco 7911 phone the phone doesn't pick up the 'Operational Vlan ID', so I have to manually configure it on the phone (this does then work).
    The port profile has an lldp profile:
    Parameter Value
    PDU transmission Enabled
    Reception of LLDP PDUs Enabled
    Transmit interval (seconds) 30
    Transmit hold multiplier 4
    Optional TLVs port-description system-description system-name capabilities management-address
    802.1 TLVs port-vlan vlan-name
    802.3 TLVs mac link-aggregation mfs power
    LLDP-MED TLVs capabilities inventory network-policy
    LLDP-MED network policy profile ucs-rnb-voice_lldpmed
    The lldp-med profile is:
    Parameter Value
    LLDP-MED application type voice
    LLDP-MED application VLAN 2480
    LLDP-MED application VLAN tagging Tagged
    LLDP-MED application Layer-2 priority 5
    LLDP-MED application Differentiated Services Code Point 46
    I didn't actually create these, I think they're probably the result of a colleagues previous attempts at getting this to work.
    The wired-ap-profile has vlan 1 untagged (which I want to use for the data vlan), and the phone vlan tagged.
    Is this a known issue? Is there something I should be doing differently so that the phone can receive the vlan info from the AP port?
