point to point
MST200 OR MSR2000 can we used for a Point to point link ?
Re: point to point
Both devices support this functionality. It would depend on your requirements. These might be overkill.
I'drecommend speaking with your Aruba partner to work out the most appropriate solution for you.
Cheers
James
