possible interference?
We have a site where facilities are installing a new wireless access accross the building. It uses a freqency of 868Mhz. Is this likely to cause any issues to the wireless data network comprising of AP105's? Thanks.
Re: possible interference?
Wireless works on 2.4Ghz and 5Ghz so I would say no this won't affect it however you could always leverage the spectrum analysis component of your Aruba controller to identify whether there is any interference.
Cheers
James
Frequent Contributor I
As the wifi network uses 2.4 ghz for 802.11 b/g network users and 5Ghz frequency for 802.11 a network users as well as 2.4 and 5 Ghz for 802.11 n network users so it will not interfere and the frequency that you have mentioned is used for GSM mobile technology.
Thanks guys for your replies.
