power
Suppose a client receving a good rssi from the ap (-45dBm) and another worst client is getting -80 dBm. and ap power max is 17dBm What will happen when the worst client talking to the ap ? Is this because of bad deployment ?
Re: power
Hey, are we assuming that each client is on the same AP and is also the same physical distance? Are the devices exactly the same? Possible interference close to the client with an issue or a device issue?
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Re: power
Hi
Distance is same  but devices are different
