Occasional Contributor I
problem AP 175 with antenna 2x2 2714
dear all,
please help,,
I have AP 175 with antenna 2x2 2714 (2,4 GHz only), as usual I provision that AP in controller as Remote AP at one AP group,
I connect Antenna 2714 to AP 175 with jumper cable to R1-1 and R1-2 (stamp 1 and 6) .
when I test the signal, the signal is low and take a longer time to connect to the AP to get dhcp...
please help, where my mistake?
thanks ..
Re: problem AP 157 with antenna 2x2 2714
pleaseeeeeee help......
