Regular Contributor II
problem on aruba guest certificate
Hi guys
We have a problem with the certificate aruba securelogin.arubanetworks,com when accessing guest network.
I know it was revoked.
We have a network with a mobility controller on 6.4.4.8 and a ClearPass.
Guest has a captive portal that gives access to network. then after login we receive an error on certifcate.
What is the best way to resolve?.
Put a new certificate on Aruba ControllerNew Bitmap Image.gif? how can we do it?
we have certificates on Clearpass. Could we use that ones ?
Re: problem on aruba guest certificate
Frequent Contributor I
Hi, I had the same problem. I made new self signed certificate and install to the controller.
Good luck
Ricardo Luis Cañavate García - ACMP / ACCA / ACCP / ACDX#972
