Occasional Contributor I
problem with Ap client with another access point, connection is not stable
dear all,
please help me,
I have aruba controller version 6.1.3.6 with 25 AP135 as RAP.
when my laptop connect to AP, connection stable, but when I connect AP client like nanostation2, picostation, ECB and another AP client connection is not stable (many drop) although signal is very good .
please help me,,  the problem has been in 3 weeks, all my client always complain to me
please some body help me...
Spoiler
:smileysad:
Re: problem with Ap client with another access point, connection is not stable
Edit: I think I misunderstood your problem but are you trying to say that some devices are experiencing performances issues when there's nanostation APs near your RAP's ?
You have probably don't this already but have you updated the drivers for those device ?
Also you could enable logging debugging user-debug <clientmac> that could also give you an idea of what's going on when these devices get disconnected from your network.
And Last thing you should consider opening a TAC case if you haven't
Thank you
Victor Fabian
Lead Mobility Architect
From your post i understand you tried a few AP clients (from a few vendors) - and it's seems happened with all of them (PC/LAPTOP connectivity are steady)
A. What encryption are u using?
A2.What is your vap working mode? (tunnel/bridge/split?)
B. what band are u using? (be sure to use 40mhz only in 5Ghz)
C.are u using WIP/RFP module?
D.Can u copy&paste from your cli/gui your aaa-profile/vap-profile/ssid-profile
give us some further technical info - in order for us to assist you.:smileyhappy:
Me.
