Occasional Contributor I
proper way to mount Aruba 330 Series?
is there any documentation that shows pictures on exactly how to mount with best case scenario for radio coverage
Re: proper way to mount Aruba 330 Series?
I suggest you take a look at the 802.11ac vrd and this doc you will find the AP mounting recommendations:
http://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/61/1/Aruba%20802.11ac%20Networks%20VRD.pdf#page27
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Get Outlook for iOS
Thank you
Victor Fabian
so, basically upside down on the ceiling is the standard best case scenario...?
In most cases , yes
Thank you
Victor Fabian
In most cases , yes
Thank you
Victor Fabian
