query on wms match method
Hi All,
I have query regarding the output of "show wms wired-mac monitored-ap-wm".
In the above output what does the monitored AP mean? which AP it is referring to?
Thanks in advance.
Re: query on wms match method
You will see this information when you have an AP acting as Air Monitor and it collects information about wired mac on the segment or segments that AM is able to collect information on
This is to determine if you have any rogue APs connected on that segment
This one works much better :
(controller) #show ap monitor wired-mac ap-name test-ap enet-mac or gw-mac
Wired MAC Table:
mac ip age
Thank you
Victor Fabian
Lead Mobility Architect @WEI
