question about ap93/105 web/cli documentation
Hy all,
I'm quite new to arubanetworks devices, i have bought 2 AP93 which are working quite right.
i've started to take a closer loook to vlan dynamic assignment and the documentation i have is not related to the AP itself, but it always talks about the controller.
I've downloaded arubaOS documentation, but it always refer to controller which i didn't bought,
so i wanted to know where can i find specific APs OS documentation (if it exists) ?
especially regarding vlan assignment attributes, which (as far as i have seen) are not documented in the arubaOS pdf .
Thanks for your help,
Xinity
Re: question about ap93/105 web/cli documentation
if your access points can run without a controller, they are IAPs, or Aruba Instant APs.  The documentation is here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=5808
thanks for your quick answer,
it sems i failed in identifying IAPs from APs, mine are AP93 or so it is written on them.
did i miss something ?
Xinity
Look on the BACK of your access point.  The only difference is that there will be a barcode that says IAP-105-XX or IP-93-xx.  Besides that, the software inside is different.
Thanks for your help, I'll take a look tomorrow
Back online,
I've check my APs, i have a a barcode which says: IAP-93
i guess it is an IAP-93 which if i am correct is "more feature built" than an AP ?
Xinity
That means it has "Virtual Controller" technology.   It can also be converted to a regular AP.  More information is here:  http://www.arubanetworks.com/solutions/instant-wlan/
thanks a lot,
I will have more technical questions, but if not already answered here, i'll open nother topics.
Xinity
it seems, you are kind of stealing a thread my friend :)
i would suggest you to open a new one, so informations won't be lost :)
Xinity
