question about mesh setup with ap-93
dear sirs,
i want to set up 3 pices of aruba ap-93 so one will be attached to the wired internet router
and the other two will extand the range of the network
only connected to power supply
can it be astablished ?
were can i find setup assitance for this case?
best regards
ziv
Valued Contributor II
Re: question about mesh setup with ap-93
HI,
It is possible scenario. you have to provision AP1 as a Mesh portal (AP which is connected to the Wired network) and other 2, AP2 and AP3 should be provisioned as Mesh points.
Please let me know if you need any assistance on this setup.
Cheers,
Venu Puduchery,
Dear sir,
I need a guide to how I can configure the mesh issue
Since I cant find any thing in the gui configuration
Thanks most kindly !!!
Ziv Hillmann
Sales Manager
Phone: 972-4-8204252
Fax: 972-4-8204272
Mobile: 972-54-2504252
Email: ziv@fiberoptic.co.il
Web site: www.fiberoptic.co.il
[logo spg]
Regular Contributor I
I am not sure if this is true, but i believe to do what you are describing you would need an AP with dual radios.
Since the AP-93 is a single Radio AP, once the Radio is configured as a Mesh point, I don't think this will support what you are looking for.
You can see more information here: http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/IAP-93-Mesh/td-p/41116
Things may have changed since then, however i am not sure how it would work.
_ELiasz
ACDX, ACCP, CISSP, CWNA
Super Contributor I
You could use it to extend the wired network but not the wireless with an AP-93. To provide wireless access while using a mesh uplink you would indeed need dual radio APs. The low cost replacement for the AP-93 is the AP-103 which does have dual radios.
ACDX #419 | ACMP |
Thank you !!!!
Best regards
Ziv Hillmann
Sales Manager
Fax: 972-4-8204272
[logo spg]
Hi friend,
It is possible to deploy Mesh with single radio APs (AP 92/93), they will work on time sharing basis.
For your ref :
Here is how to provision Mesh portal and point.
Mesh APs need Mesh cluster and Mesh Radio profiles addition to other profiles(VAP,SSID and AAA)
Step 1 : Configure Mesh Cluster profile, specify MSSID and priority of the cluster
Step 2 : Configure Mesh Radio profile ( Default profile is enough)
Step 3 : Map these profiles to the AP-group which you want to provision
Step 4 : While provisioning the AP, select the Mesh role ( Portal/Point) as shown bellow.
You can refer Aruba User guide for complete feature configuration.
http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Mesh/Mesh.htm
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
you can not do mesh with AP 93 ,  because AP 93 are BiBande but not duel Radio, and the mesh link is stablished in 5 GHz.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Trusted Contributor I
that document states: If you configure a single-radio AP to deliver mesh services only (by disabling the mesh radio in its 802.11a or 802.11g radio profile) that mesh node can not deliver WLAN services to its clients.
which tells me that you can get mesh, but only to provide then wired access to clients, not wireless.
your remark about time sharing for single radio to provide WLAN access i can't find anywhere, do you have a source for that?
A mesh node can share the radio bandwidth among backhaul and Client services. therefore we can deploy single radio as Mesh node.
If we configure a single radio AP as a Mesh node and you are expecting that AP to serve the clients also it's preformance (Throughput) will be poor coz it has to use the same radio for backhaul and client service.
It is recomanded to use the a radio (5Ghz) for backhaul but not compulsory , we can configure g radio for backhaul also.
Hope you got some clarity on this.
Cheers,
Venu Puduchery,
