Frequent Contributor I
"High Noise Floor" under Dashboard > Potential Issues
If the Controller show have the "High Noise Floor" under dashboard > Potential issues, do i need take any action? Or controller will handle it?
Re: "High Noise Floor" under Dashboard > Potential Issues
The controller will try to avoid the channel, but with only 3 available channels in the 2.4ghz range, it would be best to identify what could be causing the interference and remove it if possible so that your clients will perform better.  What is the noise reading?  If it is --85 to -100 that is not bad, at all...
Contributor II
I apologize in advance for the newbie question but I to am seeing high noise floor -77 and -72 on two of my AP's. What can/should I be looking for in the way of interference?
You should also look the amount of retries and check the AP neighbors to see if there's any other devices using overlapping channels
If you execute the following command it  should provide enough information :
show ap arm rf- summary ap-name <ap-name>
show ap arm neighbors ap-name <ap-name>
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
I'll give it a try. Thanks.
Trusted Contributor I
In 2.4GHz you'll be concerned with cordless phones, Bluetooth devices, microwaves, and other access points. Is that where you're seeing?
You can enable spectrum monitoring on those APs if you'd like try to discover the sources of interference.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Contributor II
yes primarily in the 2.4 range. How do I turn on Spectrum monitoring exactly?
In your radio profiles you can change the mode of your APs to one of the following: am-mode, ap-mode, spectrum-mode (hybrid mode).  am-mode = air monitor, doesn't serve clients.  ap-mode = standard ap.  spectrum-mode = spectrum monitoring.  If you select ap-mode, you there will be a check box to enable Spectrum Monitoring.  The AP will operate in hybrid mode, serving clients and performing spectrum monitoring simultaneously.
CLI example:
rf dot11a-radio-profile "dot11a_radio_profile"
mode ap-mode
spectrum-monitoring
Chapter 34 of the Aruba OS User Guide talks about Spectrum Analysis.
Contributor II
Awesome. Thanks
Contributor II
I have noticed that one of the AP's has neighbors with overlapping channels. I thought the controller determines the best channel to use for each AP. I suppose I am able to hardcode the channel for a particular AP...how is that done? Should I muck with that? We are using 105's.
