"can't do cli:" web interface errors
just today i started getting errors using the GUI of my 650 controller.  the erros occur any time i click on any menue item.  i've seen the following errors.
"can't do cli"
"can't do cli: system error: -2146697208"
"can't do cli: invalid xml"
to make sure it wasn't the result of something i did in the programming i wiped the config and then restored the controller with a known good barebones basline.  i am still getting the errors.
from the CLI i queried the system log and found several errors including the following:
An internal system error has occurred at file msghh.c function msghh_papi_rcv_cb line 79 error Unexpected message from 127.0.0.1:8405 code 0.
i'm not sure what is going on here?  is my controller dying?
Aruba
Re: "can't do cli:" web interface errors
Which AOS release ?
6.1.2.3-FIPS
Is this issue happening when you are logged in from CLI and webUI both at the same time?
i was logged into both which is pretty typical of how i work on this piece of lab gear.  i just tested to see if it made a difference and oddly, after misbehaving the entire morning, i can't recreate the problem now.  the web GUI is running error free.
