"ip routing" on vlan interface - what does it mean?
I'm just wondering if someone can explain in words what the "ip routing" command actually does when enabled on a vlan interface.
I don't know when it is needed or not needed.  The only time I've ever done anything with this command is to disable on the vlan for a guest network to get a cisco vpn client to work.
Appreciate a more succinct explanation than what's given in the CLI guide.
ACCP, ACCX #817, ACMP, ACMX #294
Re: "ip routing" on vlan interface - what does it mean?
That's to enable Inter-Vlan Routing which will allow you route traffic between vlans
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I assume that means the vlan interface needs an ip address then?
Yes
Thank you
Victor Fabian
