Please see attached dashboard and advise it is within acceptable or require some tuning.
mgeorge,
The thresholds that trigger those numbers on the dashboard are not configurable. Different noise floors and different levels of interference are acceptable or vary in different environments. Without seeing the numbers behind that chart and if you are having any issues at those locations, we do not know if there is cause for concern, or not.
Thanks for the reply, could you clarify this,
1) noise floor is disturbance caused by non 802.11 devices ?
2) interference is the disturbance by nearby AP?
@mgeorge wrote: Thanks for the reply, could you clarify this, 1) noise floor is disturbance caused by non 802.11 devices ? 2) interference is the disturbance by nearby AP?
Please see the presentation here: http://community.arubanetworks.com/t5/Community-Knowledge-Base/802-11-RF-Troubleshooting-Best-Practices/ta-p/20410
1. Yes and No.
2. Not necessarily
