request for proposal (RFP) for aruba
Do anyone know where i can get this documentations?
Alternetworks Corp
Valued Contributor I
Re: request for proposal (RFP) for aruba
Not really sure what you're asking for?
RFP is normally produced by a customer, who is looking for a solution.
In this case, are you the customer generating the request, or somebody responding to it?
In either case, it wouldn't really be professional to post a partner/reseller standard responses to customer requests, or another customer request document on here???
Kudos appreciated, but I'm not hunting! (ACMX 104)
is a document used to prepare proposal. usually contains all the technical information in detail, and sometimes incluides topics that differentiate the solution from others
Alternetworks Corp
Aruba
It sounds like you are preparing an RFP response.   If you are an Aruba partner, you can have a look at an RFP response sample on the partner site (link removed as it was not secured by any authentication).  It is under the Resources page under Sales Tools.    Not sure how up to date it is, and it is likely not specific to any particular RFP.    Also, if you are a partner, your local Aruba team is prepared to assist and customize an RFP response with you.
AMFX | ACCX | ACDX | ACMX
Thank you Clembo i already downloaded it :) that the thing i was looking for
Alternetworks Corp
