roaming between AP
hello,
i have deployed about 30 IAP in a warehouse and using handheld devices. but when we are roaming from AP to another the ping fails and the software used in the handheld has to be restarted everytime.
is there a solution for the roaming delay.
thanks
Re: roaming between AP
Did you do a search on the forum for "roaming" and "warehouse"?
I am asking because there is no simple answer for roaming in a warehouse and you would need to possibly change a few things to make it acceptable.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
What Joseph said.
Also, what handheld are you using?  Searching for the manufacturer or model may also help.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
