Contributor I
role doesn't apply after passed stateful-802.1x
Hi all,
   I have some problem about WLAN controller and 3th party AP. I connected AP to Aruba interface and config it as untrusted port then I connected PC with 802.1x authentication after passed authentication Aruba controller didn’t apply role from radius response its got the default role from stateful-dot1x configuration.
interface gigabitethernet  1/3
description "GE1/3"
trusted vlan 1-4092
switchport mode trunk
aaa authentication-server radius "IAS"
   host "172.20.43.131"
   key xxxxxx
aaa server-group "3th_AP"
 auth-server IAS
 set role condition Reply-Message contains "pidgroup" set-value pidgroup
aaa authentication stateful-dot1x
   default-role "authenticated"
   enable
UNKNOWN ATTRIBUTE
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  NAS_IDENTIFIER_ID:
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  NAS_IP_ADDRESS
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  UNKNOWN ATTRIBUTE
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  USERNAME
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  CALLING_STATION_ID
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  CALLED_STATION_ID
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  EAP_MESSAGE
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding to the Radius Server(172.20.43.131) len:0
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:1/smac:00:24:a8:88:4b:8e/sport:32769/dport:1812
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Received Valid Radius Reponse
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  EAP MESSAGE
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius Response to AP:172.20.43.11 len:0
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:11/smac:00:0c:29:b0:48:5c/sport:1812/dport:32769
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|   {L2} Authenticating Server is IAS
Jun 25 03:13:08 :199802:  <ERRS> |authmgr|  user.c, derive_role2:5623: {38:e7:d8:e7:6a:dc-??} Missing server group in attribute list, auth=Stateful-802.1x, utype=L2
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Adding user: 1090e3b4 (38:e7:d8:e7:6a:dc:0.0.0.0:pid2) to ap group: ap group id: 0
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Tx message to Sibyte. Opcode = 17, msglen = 188
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  MM: mac=38:e7:d8:e7:6a:dc, state=3, name=pid2, role=authenticated, dev_type=, ip=0.0.0.0
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:2/smac:00:0c:29:b0:48:5c/sport:1812/dport:32769
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Tx message to Sibyte. Opcode = 21, msglen = 128
Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  MAC: 38:e7:d8:e7:6a:dc, No L2 auth configured, L2 Deauthenticate skipped for station.
Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Create ipuser 0x0x1095b374 for user 0x0x1090e3b4
Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Called ip_user_new() for ip 10.20.20.254
Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  sta_add_l3: mac 38:e7:d8:e7:6a:dc ip 10.20.20.254
Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Adding user: 1090e3b4 (38:e7:d8:e7:6a:dc:10.20.20.254:pid2) to ap group: ap group id: 0
have anyone get this issue before?
thanks in advance
Retired Employee
Re: role doesn't apply after passed stateful-802.1x
Are you setting the filter-id on the RADIUS server as  "pidgroup"?
HT
Contributor I
Hi hthakker,
   I used Reply-message attribute on radius server not the fillter-id.
anyidea?
Retired Employee
aakmit wrote:
Hi hthakker,
anyidea?
aakmit,
You should be seeing a message like the following in the user-debug logs.
Jun 27 07:13:41 :522017:  <INFO> |authmgr|  MAC=e8:99:c4:4e:39:53 IP=10.163.207.102 Derived role 'reply-authenticated' from server rules: server-group=radius, authentication=802.1x
Following is my configuration
aaa server-group "radius"
auth-server hthakker
set role condition Reply-Message contains "reply123" set-value reply-authenticated
Can you check if the the RADIUS server is sending out Reply-message in the Access-Accept message.
You can get packet capture on the RADIUS server and filter with "radius".
Attribute Value Pairs inside the Access-Accept packet
AVP: l=10  t=Reply-Message(18): reply123
HT
Retired Employee
[ Edited ]
aakmit,
If you do not have the capability to get packet capture on the RADIUS server, you can check if the server is responding with the Reply message on the controller itself.
(master) (config) #logging level debugging security subcat aaa
(master) (config) #logging level debugging security process authmgr
(master) # aaa test-server mschapv2 <radius-server> <username> <password>
(master) #show log all | include Reply
Jun 27 09:42:32 authmgr[1579]: <121031> <DBUG> |authmgr| |aaa| [rc_api.c:989] Reply-Message: reply123
Also,
Can you post the output of the following command?
show aaa authentication wired
HT
HT
Contributor I
Hi hthakker,
thanks for your answer. I captured packet on radius server and i saw the Reply-message return attribute list in the radius packet.
Then i tested with aaa test-server command i got the resault like below.
Jun 28 06:03:37  authmgr[1565]: <121031> <DBUG> |authmgr| |aaa| [rc_api.c:989]  Reply-Message: pidgroup
 So, I'm pretty sure the radius return attribute correctly but i don't know while server rule doesn't apply to user.
(WLAN) #show aaa authentication wired
Wired Authentication Profile
Parameter    Value
AAA Profile  wire-authen
(WLAN) #show aaa profile wire-authen
AAA Profile "wire-authen"
Parameter                           Value
Initial role                        logon
MAC Authentication Profile          N/A
MAC Authentication Default Role     guest
MAC Authentication Server Group     N/A
802.1X Authentication Profile       N/A
802.1X Authentication Default Role  guest
802.1X Authentication Server Group  N/A
L2 Authentication Fail Through      Disabled
RADIUS Accounting Server Group      N/A
RADIUS Interim Accounting           Disabled
XML API server                      N/A
RFC 3576 server                     N/A
User derivation rules               N/A
Wired to Wireless Roaming           Enabled
SIP authentication role             N/A
Device Type Classification          Enabled
 Enforce DHCP                        Disabled
(WLAN) #
thanks in advance.
Retired Employee
aakmit,
Try using the following configuration instead of "stateful-dot1x"
   key xxxxxx
 auth-server IAS
aaa profile "3th_AP-aaa"
authentication-dot1x "3th_AP-dot1x_prof"
dot1x-default-role "authenticated"
dot1x-server-group "3th_AP"
aaa authentication dot1x "3th_AP-dot1x_prof"
Apply the "aaa profile" under the Virtual AP profile if the client is connected through an SSID of apply to the wired interface if the client traffic is coming through an untrusted wired interface
Hope it helps !
HT
HT
