MVP
s1500 12P noise
[ Edited ]
Should s1500 12 P does any noise?
It does a small annoying noise like whistle.
I have installed others s1500 and i dont remenber hearing that... and this s1500 goes near someone... which i bealive it will be annoying for that user.    I was looking at the datasheet and it says noise 0dB
Is this normal?????
Cheers
Carlos
Alternetworks Corp
Aruba
Re: s1500 12P noise
There have been a few isolated reports of a slight hum when connected to 220V circuits when PoE is not in use. We analyzed it and determined it was not service affecting. Once you put an AP or phone on the device, it should go away.
MVP
Re: s1500 12P noise
omg its true!
I just connected an AP to a switch 12p i got here and the hum dissapear!!!!
Thanks!!!
Cheers
Carlos
Alternetworks Corp
