Frequent Contributor II
s2500 Slot 0 Power Supply Failed
Anyone seen this alarm?
It started after upgrading to 7.3. I found that the configuration tab was not working so I downgraded to 7.2. The alarm has been active on both revs after a reboot.
How can I clear the alarm?
Aruba
Re: s2500 Slot 0 Power Supply Failed
Can you send the output of "show inventory"? If this is a PoE model, I suspect that there was an anomaly detected and so the Power Supply has shut off PoE until you physically remove the power cable and re-attach.
Best regards,
Madani
That could be. Right now i'm setting it up in our lab and I have it plugged into a 7010 controller. Both device supply poe.
(ArubaS2500-24P) #show inventory
Show Inventory
System Card Slot : 0
SC Serial # : BY0011308 (Date: 05/27/14)
SC Model Name : ArubaS2500-24P
Mgmt Port HW MAC Addr : 00:0b:86:a7:fd:c1
HW MAC Addr : 00:0b:86:a7:fd:c0 to 00:0b:86:a7:fd:ff
CPLD Version : Rev: 2.4 (0x2.4)
PoE Firmware Version : 0.0.0 (Build: 0)
CPU Assembly # : 2010152C (Rev: 06.00)
CPU Serial # : ME21000073 (Date: 05/24/14)
Power Supply : Failed (580W)
: 12V System Voltage Ok
: 56V PoE Voltage Failed
Power Supply Serial # : IP058T440RGT (Date: 04/22/14)
Power Supply Model No : 2510064
Power Supply Vendor Model No : IPSN-580APA1 (Rev: 48.48)
Console Card Assembly # : 2010111C (Rev: 01.00)
Console Card Serial # : CE21000422 (Date: 05/27/14)
PoE Card Assembly # : 2010108C (Rev: 01.00)
PoE Card Serial # : PE21000613 (Date: 05/27/14)
System Temperature : CPU Temp : 46 C
: DPE Temp : 46 C
: DDR Temp : 37 C
: PSU Temp0 : 36 C
: PSU Temp1 : 38 C
: Exhaust Temp : 38 C
: Mid Temp : 41 C
: Ambient Temp : 36 C
: Console Card Temp : 27 C
System Voltages : 3300mV Sense : 3376.0 mV
: 2500mV Sense : 2480.0 mV
: 1800mV Sense : 1808.0 mV
: 1000mV Sense : 992.0 mV
: 900mV CPU : 912.0 mV
: 1200mV Sense : 1216.0 mV
: 5000mV 5VDD : 4998.0 mV
: 5000mV 5VSB : 4974.0 mV
System Fan Tachometers : Power Supply Fan 0 : 4639 RPM (Low Speed)
: Power Supply Fan 1 : 4639 RPM (Low Speed)
: FAN 0 : 4770 RPM (Low Speed)
: FAN 1 : 5000 RPM (Low Speed)
Aruba
Yeah, this is the specific line of interest:
If you disconnect all connections and un-plug/re-plug the power cord, does the switch go back into that state?
Madani
reseating the ethernet cable turned the alarm off. Not a big deal current if thats how its designed.... I just wanted to make sure it wasn't a RMA situation.
Aruba
Yes, if we're receiving power inbound to a port, we shut-off the 56v rail to protect the switch. The 7010 shouldn't be recognizing us as a device to power up. Did you say just re-seating the cable corrected it?
[ Edited ]
It did, but the alert came back after a minute or so of plugging it back in.
I removed the ethernet and connected via fiber to avoid the issue.
I did think it was odd that the poe was triggered by the 7010. Both devices had poe lights active.
Aruba
If you disable PoE on the respective interconnect ports, do you still see the issue? Do you have Prestandard PoE enabled?
Both devices are default except for an IP address.
I can play with the poe settings when I get a chance.
