Contributor I
s3500 uplink module attaching to stack cable.
Can anyone please tell me what connector is used on the ends of the s3500 stacking cable? I understand the uplink module comes with the cable included, but I'm unclear what transceiver type it attaches to within the module.
Re: s3500 uplink module attaching to stack cable.
They are SFP+ at each end with copper in between, I believe. I don't believe there is actual fiber in it. It is 10Gbps, though.
Zach Jennings
snyer wrote:
Like Zjennings said, SFP+ direct attach cable.  SFP+ glued to both ends.
Contributor I
Thanks guys. That's what I needed to know.
But don't forget you can stack with any connection, 1G fiber or copper, 10G fiber.
We have tested stacking over a kilometer and I know it's been tested up to 70km
