same SSID WPA'Enterprise and WEP / TKIP
Dear all:
We are finishing migrating "old AP" to Aruba using  105 and a 3200 controller.
we have some old MC3090 readers that only use 128 bits WEP and TKIP while most of them are already authenticate via WPA-2 Enterprise and Internal Db.
Is there any way to keep old barcode readers and get them connected using the same SSID as the rest ?
Any suggestion will be welcome
Nelson
Nelson La Rocca
B4B Corp.
Re: same SSID WPA'Enterprise and WEP / TKIP
You should use a separate SSID for those newer scanners, because some scanners do not like a "mixed" SSID.  You also cannot mix "Enteprise" with a preshared key SSID.
thanks Joseph !
Nelson La Rocca
B4B Corp.
It isn't possible.  You cannot have WPA2 and WEP on the same SSID.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
