Occasional Contributor I
self-sign certificate for WebUI Management Authentication
I have followed a number of guides for creating a self-sign certificate to use with my controller with no avail, i have ArubaOS 5.0.2.1.
everytime i upload one and assign it to WebUI Management Authentication, after login it loads just the ui front page but all others load blanks.
Aruba
Re: self-sign certificate for WebUI Management Authentication
Have you tried from another browser to see if the other pages load?   Also, try deleting the cache on the browser in question and try again.
Lastly, is there a particular reason you are still running on 5.0.x code?
AMFX | ACCX | ACDX | ACMX
I just recently inherit this with that ver. and notice the revoke cert, easly follow the endless instructions for creating self-sign certs but no luck, always end up removing the cert via ssh web-server no switch-cert
I upload another certificate created with openssl req -x509 -newkey rsa:1024 -keyout cert.pem -out cert.pem -days 3650 -nodes
also tried: Generate-self-signed-certificate-with-OpenSSL/ta-p/275357
and: How-do-I-generate-an-OpenSSL-self-signed-certificate-in-pem/ta-p/177148
to name a few.
uploaded and nothing just the front page which i can login and view the first page nothing more.
Front page after login:
trying to browse away:
have flush dns, delete cache, different browsers
