setting static ip address for AP125
  • 1.  setting static ip address for AP125
    Posted Oct 15, 2013 12:15 PM
    hi,
    I am using AP125 accesspoint with mobility controller 3600.  I am trying to set static IP address in AP125.
    I did the following:
    Enter in the apboot prompt after restarting AP125
    apboot>purge
    apboot>setenv ipaddr 192.168.1.36
    apboot>setenv netmask 255.255.255.0
    apboot>save
    apboot>boot
    Even then, AP125 still gets dhcp IP address.
    Is there any way to stop AP125 from asking for dhcp address.  I want to make it static IP address.
    Thanks in advance.
    uv.
    #3600
  • 2.  RE: setting static ip address for AP125
    Posted Oct 15, 2013 12:41 PM
    @ubuntuv wrote:
    hi,
    apboot>purge
    apboot>save
    apboot>boot
    Thanks in advance.
    uv.
    You need to add the gateway ip:
    apboot> setenv gatewayip
  • 3.  RE: setting static ip address for AP125
    Posted Oct 16, 2013 11:37 AM
    thanks Joseph. it worked.
