Frequent Contributor II
setting tftp serverip on an AP via telnet
We are in the middle of a TAC case and as part of that we will be running a debug image on some CAPs. To test this I have been consoling to an AP to set the serverip to our tftp server, this works fine.
I now need to apply this to 3 APs out there in the field, it would be much easier if I could change these settings remotely using Telnet, is that possible? The commands I need to run are:
apboot>setenv serverip <TFTP ip address>
apboot>setenv masterip <Controller IP>
apboot>setenv bootcmd tftpboot
apboot>setenv bootfile <filename>.ari
Many thanks,
Re: setting tftp serverip on an AP via telnet
Unfortunately, that cannot be done interactively over telnet.
Colin Joseph
Aruba Customer Engineering
