Hello Experts , i need to setup master-redundancy between two aruba 7030 controllers so i have decided the following steps
provide basic config on both the master/standy controllers in terms of IP addressing/VRRP <<<<<<< connect master to the network and bring it up <<<<<<<< connect standy to the network and bring it up <<<<<< let them negotiate their roles as the master controller which was brouight first will become master because i have set the following
vrrp 104
shutdown
priority 110
authentication tr4ff1c
ip address 10.1.1.1
description "Preferred Master"
vlan 104
no shutdown
tracking master-up-time 1 add 20
so once the roles are negotiated , i apply licenses on the master contoller and wait untill it syncs up with the standby <<<<< apply user roles config / firewall ACL's and save the config and see if the config syncs up .
apply firewal dpi on the secondary and reboot it and then i am done ?
post that i will bring up the ap's and then user testing etc.
please advise if i am correct ?
