setup AirGroup for AirPlay with AirServer
Dear All,
We have Aruba wireless system with Aruba 3600 Controller and several 105 AP.
We use HP Procurve switches on our network and roughly following are some vlans:
vlan 16 - Apple TV
vlan 18 - Windows 7 desktop machines with AirServer
vlan 19 - Aruba APs
vlan 38 - Wireless iPads
The Aruba setup was done year ago by a external consultant. Currently iPads can only see the Apple TVs on vlan 16.
If I connect one of the Desktop machine (AirServer) on vlan 38, the iPads can see this machine but how do I configure AirGroup so that iPads can see all the Windows 7 on vlan 18 ? Can this be done without Clearpass ?
Any help would be much appreciated, thank you.
Re: setup AirGroup for AirPlay with AirServer
You need to be running ArubaOS 6.3.1.x or higher and Airgroup will enable this automatically.  All VLANs would need to be trunked to the Aruba 3600 controller for users to be able to see "Air" devices across subnets.
Colin Joseph
Aruba Customer Engineering
