signal strength
A smartphone is hardly getting RSSI -67 dBm while doing a survey .So Its sure that the second strongest signal should be less than -67 ,
So do we need to care  abou this ?
MVP
Re: signal strength
I think -67 is a fine signal strength - depending on what you're expecting of course ;)
We'd need to know a whole lot more about your environment to be able to give any meaningful advice. How far away from which model AP to start with.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Re: signal strength
Thanks for the reply ,I want to use cisco phone and some smartphones  for voip with excellent roaming
MVP
Re: signal strength
The signal strength you're seeing is not enough information to tell whether you'll have good VoIP roaming
Your experience will be affected by: how large an area, what kind of environment, how many APs, what other WiFi users at the same time, how much interference - and at least 20 more things I haven't thought of.
In my office environment with no interference to speak of and an AP every 75 feet or less, neg65 would work just fine.
--Matthew
