Occasional Contributor I
ssid not detect ap 103
I have controller aruba version 7005 and 2 ap 103, ap state is up. But i can't detect ssid from ap 103. Already convert ap 103 to campus wlan, need help? already 3 days for trouble shooting, but yet solved this problem.. hehehhe
Re: ssid not detect ap 103
Please provide output of
show AP remote bss-table ap-name <AP name>
show profile-errors
show AP active
hi keya_n thanks for respon
(Aruba7005) #show ap remote bss-table ap-name employee
No AP found with ap_name employee
(Aruba7005) #show profile-errors
Invalid Profiles
Profile                         Error
aaa profile "default-dot1x"     Error: Role 'authenticated' is Unknown
aaa profile "default-mac-auth"  Error: Role 'authenticated' is Unknown
(Aruba7005) #show ap active
Active AP Table
Name  Group  IP Address  11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/E        IRP/MaxEIRP  AP Type  Flags  Uptime  Outer IP
Flags: 1 = 802.1x authenticated AP; 2 = Using IKE version 2;
       A = Enet1 in active/standby mode;  B = Battery Boost On; C = Cellular;
       D = Disconn. Extra Calls On; E = Wired AP enabled; F = AP failed 802.1x a        uthentication;
       H = Hotspot Enabled; K = 802.11K Enabled; L = Client Balancing Enabled; M        = Mesh;
       N = 802.11b protection disabled; P = PPPOE; R = Remote AP;
       S = AP connected as standby; X = Maintenance Mode;
       a = Reduce ARP packets in the air; d = Drop Mcast/Bcast On; u = Custom-Ce        rt RAP;
       r = 802.11r Enabled
Channel followed by "*" indicates channel selected due to unsupported configured        channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:0
(Aruba7005) #show ap remote bss-table ap-name Aruba-AP
Aruba AP BSS Table
bss  ess  port  ip  phy  type  ch/EIRP/max-EIRP  cur-cl  ap name  in-t(s)  tot-t
Num APs:0
Num Associations:0
Super Contributor I
Have you added the necessary licenses to your controller?
Show us "show ap database" aswell please.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Certificate IDs ? ( where i get information for fulfill this question)
Super Contributor I
It comes with the email when purchasing licenses.
Cheers,
how about trial version, i can try it? i have 1 controller and 2 ap 103 for demo
Super Contributor I
Yes, you can generate evaluation licenses on licensing.arubanetworks.com.
Cheers,
Chris,
i can't find trial license menu, ^_^
