syslog settings
How do I enable auuthentication messages to show in syslog?
I have a 7210 contoller running 6.4.3.8
I have tried this. Not sure if something changed in the versions.
http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-logging-authentication-events/m-p/5328/highlight/true#M220
Re: syslog settings
Did you type "show log security 50" to see if you see the messages on the commandline of the controller?  That post was originally 7 years ago, by the way..
Re: syslog settings
I did.
It was edited 2 years ago. Might be time to edit again.
As suspected, the command has changed.
This is what worked for me
logging level informational user process authmgr
Re: syslog settings
Changed.  Thank you.
