Occasional Contributor I
syslogs send a different interface vlan on controller ?
hi all
in deployment there is a controller 650 and running version 6.4.x.
we are sending "auth. success logs" to palo alto firewall for User-Ip Mapping.
we want  to send different syslogs  from different interface vlan . Is it possible.?
thanks for your replies !!
Re: syslogs send a different interface vlan on controller ?
Are you wanting to send logs to the same location via 2 different routes?
If so, this isn't possible.
Cheers
James
Re: syslogs sending, a different interface vlan on controller ?
Yes james. i needed it.
Well, is it possible sending different location via different routes ?
thanks
It certainly is possible to send to different locations via different routes. You just need to configure a static route to the different location.
CLI
(Aruba7010) (config) #ip route <dest> <desmask> <nexthop> <cost>
CLI Example:
(Aruba7010) (config) #ip route 10.10.10.99 255.255.255.255 11.11.11.200 1
GUI Example
Cheers
James
