the distance for outdoor wireless?
Dear any one,
I want to aks about the distance of Outdoor wireless? I have two buildings, the distance between two building is about 70 - 100 meter. I want to design Aruba Point to Point.
For outdoor wireless Point to point, which model of Aruba I should choose? How long is the distance of Outdoor wirless?
Thanks for your support.
Khang
Re: the distance for outdoor wireless?
Please read this doc :
http://www.arubanetworks.com/wp-content/uploads/AP_OutdoorPointToPoint.pdf
And watch these videos :
https://www.youtube.com/watch?v=mMCra16y8Bc
https://www.youtube.com/watch?v=YAxJtRTzGOc
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Super Contributor I
Reading the outdoor VRD will definitely get you acquainted with some of the caveats of outdoor wireless. If there's a good line of sight and you're just looking to connect two networks via a point to point link I'd take a look at the MST200.
ACDX #419 | ACMP |
