Regular Contributor II
too many virtual aps configured
Hi Guys,
I have this problem in a client.
I am sure that is related for having 15 wlan 's beside i said that 4 or 6 is the best.
How many vap are possible in a 7210 controller ? 16 ?
regards
Re: too many virtual aps configured
It depends on the model of access point.  What model is this?
Colin Joseph
Aruba Customer Engineering
Hi
AP 105.
Regards
EDIT: All APs should support 16 BSSIDs/radio (except for the AP68 and AP105)
Colin Joseph
The AP105 only supports 8 SSIDs
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi thanks for the info guys..
and VAP on the controller 7210? is the limit 16?
Regards
PS: Obviously I am a fan of not having more than 4 ssid's on the air...
There is no limit.  The AP rejects if it is over the limit.
Colin Joseph
