turn down power on IAP 315
I have a customer that has several IAP 315s in an office area.  They are fairly close to each other (for better throughput per connection) and I wanted to turn down the signal power on each AP so there was less bleedover. All of these AP's are in a zone, how can I change the power level for these APs?
Re: turn down power on IAP 315
You would use the ARM minimum and Maximum transmit power to determine the power of an AP.  If you want all of your access points in the cluster to the same power, make the minimum and max the same. http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm?Highlight=arm
 If you want to make an individual AP a specific channel and power, you would need to edit that AP and set the channel and power manually under the radio button.  You cannot set a min/max range for a zone.  You would have to statically configure those access points when you click on edit next to the access point.
